alternator terminal
55 50 Ron
Here's one I haven't seen before. What is the use of the little terminal just above the main output terminal? Has the letter R beside it. It's a re-manufactured Delco Remy. Thanks
Ron
If your talking about that little nipple looking thing above and to the right of the battery terminal that is one of the diodes if I remember right
Believe that is a tach signal, for an alternator driven tach, usually on diesels.
Don't touch it running, it's AC voltage!
(quoted from post at 18:57:30 09/13/21) Believe that is a tach signal, for an alternator driven tach, usually on diesels.
achometer connection is likely.
just a connection to center of stator "Y" windings.
