Geo-TH,In
Going to look at friends Truck today. He says his turn signals don't work. Also he
says the radio stops playing when he turns the signals on.
It sounds to me there is a problem with the auxiliary power switch. Where is the
switch located???
I plan to locate turn signal fuse and confirm if the switch is bad when it under the
load of the turn signals. He also have a 5th wheel trailer that uses turn signal
power.
I may do a work around and power turn signals with a fuse from battery and remove it
from the auxiliary switch. If the guy turns truck off and can't tell his turn signals
are still on, it's his problem..
So where is the Auxiliary power switch??
switch located???
power.
