Stubborn as a ..
Mule, specifically a 3010, I think about 2003. Bought it at a bargain price because it wouldnt run .With a lifetime of experience I thought it would be an easy fix.If I jump the relay behind the battery it turns over OK. Electric fuel pump doesnt run, also no spark. I checked neutral safety switch, it is OK. All the fuses are OK.I am almost certain one of the muleskinners on this forum can suggest the next move. I will await your input before I panic. TIA Sam Womer( PA)
I'd start by hot wiring it. If you have spark when it is hot wired then the problem is from the coil back. If it still doesn't have spark it in from the coil to the distributor
just what tractor are you referring to?? when u say 3010 i think john deere from the early 1060's. then ur talking electric fuel pump and safety nutral switch.?? better give a better descrition of this unit.
I bought a shop manual for my 2016 4010 Mule with EFI on Ebay. There are several 3010 manual s listed on CD from $7.95 to $69.52.
