Engine runs to fast, idle speed is fine ,but when throttle is barely moved the engine over speeds. Someone has replaced the gov. and carb. with after market stuff and the old carb and gov. are not to be had. I have had both carb. and gov. off and found nothing wrong. I once rebuilt a carb on a NAA, installed new throttle shaft that came with the kit and it acted the same way, put the old shaft back in and it ran like it was suppose to. Looking for others opinions/experience as to what may be a fix. I am not limited as to getting this to run right.
Thanks in advance.
Thanks in advance.
