Farmall H Transmission Fill Plug
DelMN
Could someone tell me what size the Farmall H Transmission Fill Plug is? I think it is 3/4 inch female plug if I recall correctly. I am not close to the tractor so I can't just go and look. Thanks
Yep 3/4 square headed bolt fits into the bung and gives you a great access to fill the housing with 140-90 gear oil. Used to keep a 2 1/2 inch long square headed bolt that took a 3/4 inch wrench in the tool box. It worked with either a pipe wrench or a vice grip to open the bung. We didn't have a 3/4 drive socket set.
Pipe threads and bolt threads don't play well together without leaking in the threads. Check plug on ours I would have to check size though thought it was about 1/2 pipe thread. 3/4 pipe sounds to big for the check plug by the clutch pedal.
