Whats been your most
SVcummins
Reoccurring breakdown this year ? For me its been a tire year ! See Robert now youve got me saying it now . Tractor tires trailer tires and baler ties oh my
Yep, same here. I've been dealing with electrical gremlins off and on all year. However I did notice the 4430 front tire slowly going flat yesterday. I now know I can blame it on SV for jinxing me.
Like you ,tires. In 1 week 2 rear on tractor 2 on baler 2 on cattle trailer and 2 on pickup.
Should be good for a few years I hope
A/C on the 2590, it has proven to make new leaks every time I use it. It will get a completed overhaul of the system this winter.
SV,
I have a daily reoccurring problem.
Either my hose is too short,
or my pump is too weak,
because If I don't sit down when it time
to drain my radiator,
or I'll have wet feet.
I had to clean up my reply, Draining radiator means something men do standing up and women do sitting down. Get it??
I just took a quick count and came up with 101 tires on my stuff and I probably missed a few. I'm fixing 4 tires right now. Makes a good argument for steel wheels.
Add these two to the list which I forgot. That makes it 103 and still counting.
SV I feel your pain. Been the same way here too. Had 2 different harvester's 14.9-24 front tire bust in the same field about 5 minutes apart on the same day. Been running anywhere from 2 to 8 flats a day. Some of these are brand new tires.
Wow thats not good. Check your left rear tire , by looks of the picture you may be having a tire year too.
It was Roberts fault he started it . One thing about tires its not like a knotter problem or an air conditioner problem or wiring its not voodoo with a tire you Just pay a bunch of money and its fixed
that was last year so I sold the d junk now it is someone else problem. after I replaced both tires on bale basket
Oh, you reminded me of the wheel barrow. That's another one but, no. The one I counted was the single drive wheel on a mounted Great Plains drill.
Oil leaks! Everything I use has had some type of leak to deal with. Today it is the oil pressure light sending unit. Was new last year and leaking again. It is the same type and bought at the same place as the one that gave me fits on the skis loader this spring. That store gets a visit from me tomorrow. Hydraulic valve on the DC, and 400, line on the combine and mower. A seal on the power steering on the 400 this spring. There were a couple hoses this spring as well. Even my wife's new car had a transmission line leak, same line twice this year. Had about enough with the oil leaks.
I hate oil leaks . I always seem to have an oil leak on something . Even cheap oil is to expensive to oil the driveway with
Ya blame it on me.. Been telling SV all spring and summer its a tire year..
mine started in FEB with $1200 worth of tires on the wifes blazer... and it hasn't slowed up yet.. rear tires for the 861, service call/flat fix with fluid on the 18.4-42 on the big deere.. new set of rears on the rake tractor.. a dual for the 4000 that took 3 trips and over $300 to get fixed.. numerous trailer tires.. maybe ill have em payed off in time to do this rat race again..
Oh and my pickup is almost to where the air will show thru... if it makes it thru harvest it will get new tread for winter and hunting season
