Belarus 825 is hard to get into any gear. It has always been a problem but is worse now. If I almost shut down the engine (idle to almost stop) I can ram into gear without grinding and then rev the engine back before it stalls. I'm quite good at this now with no stress on the tractor.
Can anyone tell me how to adjust the clutching system so I can get this thing to shift normally without having to be a magician?
Peddle travel or other? Note: the clutch does not slip once in gear it just will not shift without grinding unless I idle it down or stop the engine and then shift and then restart.
Thank You
Bryan
Thank You
Bryan
