JayinNY
I was talking to my neighbor today about the wobble box on my haybine, he told me I should use Napa 90w mineral oil, he is a mechanic, my new Holland manual says to use APIGL5 80-90, does it really matter? I already have 80-90 on hand, thats what has always been in it, thanks
Mineral oil may or may not have additives for extreme Pressure, corrosion inhibitors or other important modern additives. The synthetic 80-90 (as SV indicates) would be my choice. Jim
You have the recommended oil, use it.
Reality is it probably doesn't make enough difference to matter, the difference being a trip to buy the other type of oil, and having to store an extra jug.
Only place I've seen 90 mineral oil called for is in my old IH Scouts. Can't remember if it was for the trans or TC but certainly not the axles. I had to buy a five gallon bucket and used about five quarts. Still have the rest.
Only if the gear box has yellow metal components should you use straight mineral oil.
The GL5 has EP additives, needed for the gear load protection.
I would use the 80-90w as NH recommends. A few older transmissions used to call for mineral oil but I see no advantage in going backwards as far as oil/additive technology.
GL-1 does not provide pressure point protection that GL-4 and GL-5 does .
Straight weight 50 motor oil that is rated for GL-4 will work just fine . Yellow metal and clutch fibre friendly too.
