super99
I've been fighting the carb on my new to me Oliver 1550 all spring and summer, it wouldn't idle below 1000 rpm. I've had the carb apart more times than I can count on both hands, boiled it in vinegar and soaked it in Napa carb cleaner a couple of times. Today, I took it apart before noon and put the top part in the carb cleaner and left it in until 4. I cleaned it up and squirted carb cleaner thru it after running a wire thru the passages, put it together and started it up. It runs perfect and I got the idle speed down to 450 to 550 rpm. I took it for a short drive, 6th gear, pull the throttle back to idle and it chugs along at 500 rpm, push the throttle ahead and it smoothly increases speed. I better buy a lottery ticket!!!
