I installed a new 12 x 38 rear tire on my JD-B and I can't get the bead to set and seal completely on one side of the rim.. One side is completely set , but the other side will not set the bead in the rim .
I pumped up the tire to 45 ibs and soaked it with a special tire bead lubricant and still no luck. I deflated and inflated 3 different time and still no luck. The max pressure on the tire says 35 lbs, and i have already put in 45 lbs. Can I put in more than that and still be safe? Is there another secret to getting it to seat?
