Tree-Farmer
I bought a used air bubble, 10 gallon, Powermate, but it's not working right.
It blows up a tire very very slow. I was able to blow up a riding mower tire, but the air doesn't come out very fast. I tried to blow up a tractor tire, but I can't hear any air go into the tire and the gauge stayed at 80psi after I held the end on the tire for 2 minutes.
What would be the most likely bad part? Do you think it would be the black rubber hose with the end?
Or would it be the gold colored valve that screws into the tank, and the rubber hose screws into it? What does that valve/connector do? Could it be bad?
Or what do you think is wrong with it? Why won't it blow up a tire very good? If I push the little valve inside the end, air does come out.
Thank you!
Thank you!
