New Holland 545c injector pump timing?
Mcoby1988
New User
Trying to reinstall injector pump on a 545c no keyway, no bolts just a tapered shift and a big nut to hold gear on
I wish Dieseltech was around, but he is on a long tractor ride. Which pump do you have? If it is the one I think it is you
might be in deep stuff. That pump needs to be locked before removing the gear. Engine needed to be timed, pump locked and the
shaft pressed out of the gear. If you didn't lock it before removal,you will have to send it to a rebuilder and get it
retimed, locked and then you will have to figure how to get the engine in time before installation. Been there done that,
Lessons learned the hard way you never forget.
Let me guess, pump model starting with 89? Thats a DP 200
series pump that engine and pump both MUST be pinned/
locked for correct installation as Welding man said. Pump is
locked in correct location as last step of calibration...
