Kubota 7030
WNYBill
I need the good, the bad and the ugly on a Kubota 7030 with <4000 hours and FEL. I know it is a little new for you guys, but I remember a couple of Kubota experts on the site. Has a 16 speed Trans but no shuttle, is it a beast to load with?
Thanks
You did not say 4 wheel drive or not. The clutch would be the weak link in any manual gear tractor. Sold a lot of them and almost trouble free. Motors run forever and all the rest is pretty simple. Loaders back then were made by Great Bend for Kubota but valves are easy.
It is a M7030su, 4wd with a Quicke loader. Open station with a canopy. JM, tell me a little about the transmission, Tractor Data says it has a 16 speed trans with 4 reverse gears. So I presume it has a 4 speed trans with a 4 range transfer. Might be a beast if you were using the loader a lot? The bucket looks very good, no dents or etc., maybe not used as a bulldozer. I can understand possible clutch problems. Sounds like I need to see the service records.
Thanks,
Bill
