(quoted from post at 08:28:28 07/18/21)
(quoted from post at 08:50:40 07/17/21) Well if that is how the fuel lines are hooked up it will NEVER RUN . And timing marks are on the flywheel under the cover on the right hand side of the bellhousing along with a pointer that you SHOULD find under the cover once you remove the cover then you use the cover bolts and bolt the pointer back down . If that is the picture of said pump it sure does not look rebuilt . Correct timing for a R D pump is 50 Degrees BTDC . also since you have no idea as to where the pump is timed remove the timing window on the side of the pump and look for the line on the weight shaft and align that with the X mark . IF you have NO timing pointer under the timing hole on the bell housing then get one off any 706-1456 from a bone yard . Clean the WHOLE FLY WHEEL side off and you will find timing Numbers.. And get your supply lines hooked up to the filters correctly .If you can't then find and OLD TIMER who knows these tractors from when they were new . R D pumps were replaced on many 806's way back to the Roosamaster , BUT there are still some out there . That line you have running back into the suppl pump is NOT right as it needs to be going to or from one of the fuel filters with one running back to the other filter then from that filter back to the inlet to feed the head of the pump
Brother has everything aligned as you noted. His got everything in time, but the mark on the front of the pump housing isn't there (mark is noted in the manual). He can see a 10, some slash marks, 15 and a few more slash marks or words of that effect. I'm guessing degrees.
Again, he says it's just off enough that it won't start without a small shot of ether. So close, but won't fire up.
I need to have him write out whatever. What it is, my brother can't set before a computer. He will mess it up bad and not enough touch it. Something about his body. He can put on new wrist watch and have it dead in few days time, if not in a day. He can use a pocket watch for maybe a month. He can't walk through the doors of stores without the alarm going off. No one can explain why he does this. So it's print out whatever and let him read it.
He is a retired mechanic. It takes a semi trailer to hold all his tools. The trailer parked in side yard.
