Really Enjoy your website!
Having an issue with my 656 cutting out and stopping after about 60 -90 minutes of use. I let it stand for 30 minutes and it runs again. Few years ago thought it was a fuel line issue due to debris so raised fuel line into tank about 2 inches to reduce plugging of the filter. Had thermostat replaced - same issue
Wondering if the exhaust manifold heat control spring is not working?? Last Fall the spring came off during field work and when I moved the sloted bolt that spring attached to close the valve it
seemed to help Wondering if spring not working properly before it fell off would cause cutting out
Thank you !
Tom
Thank you !
Tom
