Ford F1 Pickup Coil
My 1950 F1 has a faulty coil. Tractor related because it's stable mate is my 1950 8N. Do I need a coil specifically for a positive ground or will any 6V coil work? I'm assuming that the + terminal on the coil goes to the distributer wire.
Yes you can use any 6 volt coil,if you still use the 6 volt system. yes the positive will go to the distributer.
