I replaced the starter solenoid on my Case 300. It has 3 posts (1 for battery cable, 1 for starter cable, and 1 for ignition switch cable.) I get an arc when I try to hook up the cables at the battery. It still arcs with the switch cable disconnected from the solenoid. The posts on the solenoid are not grounded to the body of the solenoid. However, with the ohm meter I get a circuit from battery cable post to starter cable post on the solenoid. This would mean that power would run through the solenoid to starter with the ignition off. Is this correct or do I have a bad solenoid?
