Could a bad ignition coil be my problem. I have replaced the neutral safety switch, ignition switch, both battery cables, the cable from solenoid to the starter and had the battery checked and it was good. I can't find any loose wire connections or breaks in the wiring. It cranked fine and then all of a sudden the ignition wouldn't do anything. Several times in the past I had to wiggle the gears for the ignition to work. That was why I replaced the neutral safety switch first. I have someone coming that can test the wiring but I don't know when as I have been waiting several weeks.
