Wagner wm4 loader
Matthew87
Can anyone verify this is a Wagner wm4 loader. I was told it was and it came off a 8N and the front brackets dont seem correct to me.
Here's a couple pics of my WM4
Here's how it mounts to the front of my 9N
8N's mount a little different at front
Okay. Ive seen that style. I circled the picture as to what Im
referring to. They just look out of place to me.
Are you going to put this on an N?
If so, Have you given a thought to how it will require you to climb up on the the 3 point arms and over the back of the seat to get on the tractor? Have you considered how slippery it might be to do that? Or how difficult it will be to steer a tractor with that big thing clanking on the front end and what a behemoth it make your otherwise nimble N? Or how you'll need to add a thousand lbs to the back end to have any traction? And what the increased compaction on everything you drive over will do?
Have you an inkling of the increased wear and tear on your front axle? How you will break spindles and wear out the center pivot? And bend radius rods and drag links and wear out tie rods and your steering box?
I gave a thought, Once, to putting a loader like that on an N, for all of about a minute. I decided then and there I would Never punish the tractor, or myself and do such a thing.
