I tried some handy home machining work on one side of the
axle I thought I had it cleaned up good enough to seal but it
didnt . Got a national brand sleeve they are half the cost of
the speedi sleeve brand and I could detect no difference
between the two. I can only find one size of 3 inch sleeve
even after pulling the scored part off still had to remove about
.250 thousandths so with my trusty cutoff wheel I cut of the
excess then with the flap wheel I chamfered the edge of the
sleeve so the seal could slip over without damaging it
Had to get a new rake tire turns out p205 75 15 is as close to
a perfect match to original tire as youll get with getting
another drive tire of the same size
