Old diesel fuel
farmguy
I have a 1086 international I don't use much. Fuel is two to three years old. Any additive I can ad? thanksfarmguy
I worked on a TD15B last year and got it up and running for the owner. It had sat for about 10 years not being used or run. I checked the fuel for water and it was good. I fired it up on the old fuel it it ran just fine on that 10 year old diesel
Generally diesel keeps really well for half a decade or more.
You could run into the bacteria if there is water in it. There is a simple additive for that.
Probably be just fine tho, fire up.
I bought a diesel tractor that had sat in a shed for 15 years. We cranked it over , gave it a wiff of ether and it fired up and ran. We loaded it and took it home where we fired it up to unload. I did drain the tank because of rust and contaminants , but the fuel was fine. We filtered it , added fresh fuel and had a running tractor.
