ChampagneNBeer
Hi All,
Couple of generic oil questions...
Found on the farm several quart, gallon and
larger full, unopened oil containers in
plastic jugs, small 1 qt cans (think of
those needing to be opened with a can
opener) and drums.
1st:
Does oil go bad in unopened containers - if
yes, what would the shelf life be?
Could one use without issue all the older,
unopened oil - plastic jugs and small round
cans equally?
2nd:
I noticed Shell T1 SAE 30 over the years
has been labelled as Heavy Duty Diesel for
diesel and gasoline engines, whereas other
T1 30wt heavy duty oil indicates either
diesel or gasoline and some just says heavy
duty oil.
Is this all the same, as it all says Shell
T1 heavy duty 30 wt, or are there actually
different versions of T1 30wt heavy duty
oil - some for diesel, some for gas etc,
and some for both?
3rd:
Also found several non-T1 heavy duty SAE
30wt oil containers, Mobil, and other
brands - same question as #2 above.
4th:
Considering modern T4 and T1 diesel oils
are much superior to straight 30wt from the
60's, would mixing un-opened T1, T4 etc
containers be a no-no?
Lastly, if older cans can be used as it
doesn't degrade, is there a value to
keeping the old vintage cans and buying new
oil, or just use it all up?
Thanks ,
CnB
opener) and drums.
1st:
cans equally?
2nd:
duty oil.
and some for both?
3rd:
4th:
Thanks ,
CnB
