535 JOHN DEERE MAKING NOISE LIKE A HAMMER HITTING TUBE
Been rolling for three days straight, noise getting louder by day. Already replaced bearings in three of the four inch rollers. today we put a heat gun on all bearings, nothing that hot to point to a bearing. Is it possible for the hex shaft to break into slapping the inside of roller tube?
Hex shafts have a history of making knocking sound from excessive clearance inside brg inner race. If brg don't test hot then I'd continue baling hay.
(quoted from post at 12:00:55 06/15/21)
Today will wind up first cutting. Got to keep her together for a hard day. THANKS
Don't worry about the knocking. Happens with hex bore bearings and load.
Don't lube them! Might spray a little water on them, not much pressure, and allow the rust to stop the
knocking between bearing and shaft!
(quoted from post at 18:24:51 06/15/21) Don't worry about the knocking. Happens with hex bore bearings and load.
CAN'T explain it , but after two rounds around field she quit knocking and rolled 77 rolls just like a new one. Thanks for all the input.
