52 8N starts right up and runs great in all speeds 40 psi startup
working 30+ no lower then 20 psi warm idle. No smoke at startup.
Working faint tailpipe smoke.After sitting at idle, throttle up and
blue smoke is very thick like an insect fogger and goes back to just a trace when I go back to idle It is using a good bit
of oil even seems to be liquid oil at the end of the tail pipe. No blow by none.Now a few days ago the needle and seat in carburetor gave up and when I remove the (updraft) carburetor gasket is soggy with oil and the inside of the intake manifold has a thin coating of oil. The oil bath breather has a full compliment of oil and with it disconnected still smokes so I know its not pulling oil from the bath.
