Question on CAT 3046
Fritz Maurer
I cant get the injectors out. Made a pipe puller with
a draw screw threaded onto the top of the injector ,
and they aint moving. I got plenty of power on tap
but how much will they take ? Thought I should stop
and ask before I bust something. Thanks, Fritz
Those can be a PITA, you built the right type of tool. They can take a lot, a mix of ATF and acetone sprayed will sometimes help. I did have one instance to where one would just not come out with heat, hours and hours of labor, and every pull twist and pry motion you can imagine. The customer agreed to pull the head and I worked and worked on it, and finally drove it out from the bottom. That is actually a Mitsubishi engine that Cat acquired when they took Mitsubishi's heavy equipment division over.
