Will pull starting a diesel tractor get
air out of the system? I have a little
Iseki that will not start. I did all the
normal troubleshooting and still nothing.
This weekend I installed new injector
nozzles and have good spray from them.
Still nothing, just lots of white smoke.
I have bleed the lines like the book tells
me to, even tried spraying silicon spray
in the intake. Nothing. I know
compression is low, 380 and 340 lbs which
is probably my problem. However it was
running when I turned it off, and now
won't start back up. I figured I would
pull start it before I remove the head.
the engine is a Mitsubishi KE70
Thanks.
Thanks.
