How to adjust cultivator
Geo-TH,In
The last time I cultivated was 1966.
This is how I remember a cultivator worked.
I would go flying and if I blinked I wiped out about 25 ft of 4 rows.
Speed and how much dirt went into the row were variables along with how the you adjusted shields and shovels.
geo.
organic weed control
I cultivate my garden,sweet corn,etc,have yet to find a weed or any plant that was steel resistant.I use disk hillers a lot, can get very precise with them.
Plus if I sell produce I get a premium.
Morning glory and Canadian thistle love it when you cultivate it its just giving it 60 units of nitrogen to the original plant and then spreads it all across the field
Many people tell me,,they cant have a garden,,too many weeds in their soil,,,
It can be done,,,hoe or cultivate before it needs it,,and keep it up,,dont say Ill get it next week
Weeds wait for no one,,,lol/vphoto87643.jpg>
Some pictures from different plots I have done over the years,,,no spray,,just kept at it with tilling and hoe
Thistle are a result of too much P compared to K,the more out of balance your soil the worse your weed problem.Never seen a thistle in a corn field or garden in my life.
I've been planting basically in a trench and fill the soil in around the plants as they grow and cover up the weeds between the plants.Leaves very little hand work,also letting the ground warm up before planting so the vegetables take off growing fast makes it easier to control weeds.We raised a good amount of corn when I was growing up and always cultivated.
I cultivate till it gets to big to cultivate. I mulch all but the corn and peas.
Farmall 100 & a 140 that's all they do is lay off rows and cultivate...
The 140 had a set of rolling cultivators on it I will try to post a pix when I use it next it does a bang up job...
I never take the hillers off the 100 I row with it sometimes cultivate with it and use them to throw the dirt to the corn.
BTW whuts a rock : )
I grew up on the cultivator. JD. 60 four row front mount. There's a knack to it for sure. Set the shovels close, replace shovels if worn, Set each gang perfect depth, set each shovel on gang perfect depth, adjust shields just right according to crop height, change as needed, drive right speed to cover weeds but not crop, stay awake, readjust all those things when you go to next field. But we really had clean fields. Then when we wore that cultivator out Pa bought a rear mount 4 row and put it behind the 700 Case. I hated cultivating with the front mount but I really hated cultivating with the rear mount. Cultivate the corn 4 times if possible and the beans 3 times. Pa would start cultivating around 7 am. then I would take over around 10. Stop for dinner then I would go out until about 4. Then Pa would take over and stop for supper then go back out until dark. We had about 250 acres of row crops so we really had to keep that cultivator going. I still cultivate a little of my own and then the 80 acres of organics I custom farm for the neighbor but I have a 12 row so when I make a couple rounds, I'm way over here already. Lots different from growing up with the 4 row.
When I had to cultivate We flu alright, low gear at a idle with a 36 JD B, hand lift cultivator. When I got to the end, I had to get off the seat and use both hands on the lift to get it up, or down while it was moving, then jump back in the seat before it got off the row. Tried to get through the corn and beans three times each before they were too big. Last time through, Dad would turn the disks around so it would hill and cover the weeds in the rows.
How about a tangle of morning glory across the shovels on the side you are not watching! LOL
Or a badly sunburned back because you did not have your shirt on!
Or getting on the wrong pair of rows!
Or trying to stay awake with waist high corn flap-flapping under the cultivator mount bar? (final cultivating fast as possible to throw dirt around the plants)
Or all day quick dodging the misaligned plants due to a stretched corn planter wire (cross cultivating).
Or the warm exhaust wafting in your face when the wind was right!
Or when your school/townies were learning swimming lessons in tow that day!
