Long shot here. Cub belly mower belt.
old
So the belt on the belly mower went AWOL. It has a Kub Klipper mower deck. Any body by chance have the belt number for it?? Not sure it would be the same as the belt for the Woods deck
Thanks
I have the old belt so I can take that to O'Reilly's but it sure would be easier to have the number since there is about a 50/50 chance they would have it on hand
This was on the farmallcub.com forum
User avatar
chief
10+ Years
10+ Years
Zip Code: 71913
Tractors Owned: Farmall Cub
Found Belt for Kub Klipper
by chief Sat Jul 10, 2010 3:26 am
I found a Kevlar Belt for Old Smokie and it works fine I mowed two hours and it still looks new, and the price was great also shipping and all $ 38.05
it is a Kevlar 5/8 X 140 Part number is B137K from Belarus Tractor International, 7842 N. Faulkner Rd. Milw., 53224 www.vbelts4less.com 1-800-356-2336
Hope this can help others with the Kub Klipper mower decks. And it should work on the old woods mowers also.
Well I hope that is correct since I just ordered one. Cost was a bit more but at $42 for one from them or $125 from O'Reilly's I'll take the lower priced one
THANKS
(quoted from post at 17:13:17 05/05/21) Well I hope that is correct since I just ordered one. Cost was a bit more but at $42 for one from them or $125 from O'Reilly's I'll take the lower priced one
THANKS
Geez!
They must think it uses Cub Cadet brand belts, which are always on the high side.
I got my last kevlar off internet. I knew the size I needed. Wasn't that expensive. More than a regular v belt.
I ordered one from the place the other guy told me about and it was less then half what O'Reilly's had said plus O'Reilly's did not have it in stock like there computer said they did
When I needed one my old belt was still in one piece, so I attached the end of a 100 foot measure tape to it and ran it around the run, that
gave me the outside measurement. Then I found a chart online that told me the pitch length, we ordered one and it fit fine. All tractors
with the same mower might not be the same, they can be mounted differently, at least a Woods.
If it hadn't happened I would not have believed it but I called them yesterday right after you gave me there number and it got here today. Never had a part or other such thing come in this fast
I ordered a belt from them yesterday shortly after I got there info from Joe and if I had not seen it happen I would not have believed it but I got the belt in less then 24 hours
(quoted from post at 15:21:53 05/06/21) I ordered a belt from them yesterday shortly after I got there info from Joe and if I had not seen it happen I would not have believed it but I got the belt in less then 24 hours
I think they are like Rockauto, just a third party retailer shipping from several vendors all over the country.
Is there any address on the box indicating an address it came from?
(quoted from post at 17:31:19 05/06/21) Says on the box WI. and I am sure it could not get here from there that fast
If they gave you one you can look up the tracking number to see where it really originated.
But even if from Milwaukee it could get to you over if ordered at the right time of day.
