Hey Guys,
I have a early model 2240 that has seen some abuse. When I bought it several years ago it was missing the cover for the transmission case fill. The hydraulics wouldnt work very well and it would plug the filter in a few minutes of run time. Turns out the transmission case had a layer of dirt in it. I flushed it out with diesel and replaced the hydraulic pump. I also had to replace the rockshaft piston seal. After all that it has worked pretty well the last few years.
Recently I noticed leakage past the rockshaft piston seal and decided to tear it apart. Unfortunately I found the cylinder walls were badly scored and there was a lot of metal flakes stuck in the piston seal. It looks like the metal was coming from the front of the cylinder, I think it may have been caused by the piston traveling too far forward and hitting the front of the cylinder. Is this likely? Is there an adjustment that need to be made? Im going to try to purchase a new cylinder assembly and dont want to repeat the performance.
Thanks in advance for any suggestions!
Joe.
Joe.
