On Modern View ..Search.. in rectangular red box at the top. I dont know what you are looking for, if it is a specific post you are looking for and would have some unique word not that common in ..tractor speak.. you can search for it works best. If you put ..Farmall seat.. in for a search it will give you results from every time those words are used, like valve seat or needle seat. So you have a lot to wade through. There are some ways it says to limit the returns by following instructions there, but I have never been real successful with getting that to help me. The author search works well, but I have found that if you try to search a specific term in a post from a certain author it can be finicky. Some times I have had good luck just using a regular search engine like Google type in Yesterdays Tractors and whatever I am searching for.
Search works fine if you select the right options. The most important is to select "search for ALL terms." Otherwise you only get searches that contain ANY of the words you put in.
