1086 hydraulic remote keeps popping hoses out
Kory1998
Went and ran shredder on 1086 and it has dual remotes, one remote holds hood, the other keeps spitting one hose out, have swapped hoses to see if it was fittings and it didnt help.
I have pioneer ends on shredder. Is the coupler the problem?
If you swapped them and the problem stayed with the coupler then I would say that's the issue. Might be worth a try cleaning and lubricating the balls and collar but if it continues then replace it, they do wear over time
Are they breakaway couplers? Are they only doing it when you turn by any chance? I have a disc that the hose will catch on something now and then when I turn and it pops out of the coupler.
If you have other tractors and they all use the ISO coupler size or the pioneer models I would when dismantling it change it to the ISO ones so they would interchange without having to use adapters or short hose converters.
