eagle hitch lift cylinder seals
jakecase
I Have an early case 430 and I may have to replace the seals in on lift cylinder piston....where would be the best place to get a kit for it?
There may be two different types so you may need to pull yours before you can order new seals. Case 300's were that way and the 430 had the same
set up. Luckily, John will know for sure. 315-585-9826. The housing is just heavy enough to make a hoist a real aid, especially putting a little upward
pressure to help break it loose, and lowering it into position.
