old
- Location
- Camdenton Missouri
I now have all the valves freed up. The #3 cylinder exhaust valve was the last one and I like to never got it to come out of the block. Had to take a pair of vise grips and clamp them to the valve and then used 2 big screw driver to pry it up and out and even then I had to lay things under the screw driver to raise them up. I'd be able to have it up and running today if the manifold gasket had come in. But they will be in tomorrow so I can do every thing but the manifold. Doing an oil change and filter and will put the head and tappet cover on so all that is left is the manifold
