Today's funny
jon f mn
Pa built one wagon with 37 Plymouth spindles. Well if that doesnt screw with a young boys mind!!
Which side of a chicken has the most feathers?
The outside! Heard that on the radio this morning.
Stupid stupid budd wheels . Driver Ive got a loose lug nut me no you have a broken stupid inner nut well since were this far apart may as well do wheel seals bearings brakes and s cam bushings . If I never work fleet maintenance itll be too soon
(quoted from post at 06:21:47 03/20/21) And then you change a plow share and it all goes out the window
And when you are trying to wrap teflon tape around threads.
(quoted from post at 10:37:54 03/20/21) Except when changing a circular saw blade.
rankshaft/flywheel nut on lawn mower engine.....now a shorter crank shaft. :(
Good morning, db4600: Not only Mopars for several years, but also Studebaker during roughly the same time frame. I have a 1945 Dodge pickup, I painted the lug bolts on left side of vehicle red, right side green, helps me a little...
BTW, I wonder, if I lose several left hand lug bolts, would any auto parts store have replacements? Seems doubtful.
Dennis M. in W. Tenn.
Or asking a young stud helper to go and put a square thread in a round hole OR to go dig half a hole. Wingnut
I never understood the problem. Turn them so the wrench turned towards the front of the vehicle on the topside will loosen them and reverse to tighten. Plow points were a different animal as we had both right and left handed bolts for them and they got used as which ever was handy at the moment so might have 3 lefts and one right or any combination of that.
