1946 BN IHC
[Original message 3/06/21]
After a grand amount of assistance from others, the final out come of the situation is as follows: Key switch most possibly faulty and not
grounding out, found an alternate diagram for a 5 pin switch and ordered one for about $11.00 Canadian, Found a diagram for wiring 5 pin
switch:: all this after much wire chasing, and re chasing, checking that all wires were in correct position and not on wrong connector,
enlarging diagram to make certain of all connections and wires, AND copious amount of assistance from others.
Found a new diagram for a 5 pin switch with a starter /generator and will wire up accordingly when I pick it up / and discard the old one.
Thank you to all for your assistance.
Wm.
Wm.
