dieseltech 826 pump
My 826 hs the D358 german. It has a german bosch pump. It is leaking out of the throttle shaft. Is there a seal available? Is this something I can do myself?The leak is a constant drip,it doesnt
seen to affect starting or performance. It just makes a huge mess,and wastes fuel by dripping on the ground.Thanks.
Whenever a leak shows up, it's wise to have the complete pump re-sealed. There are other areas that WILL soon leak after a patch job is done. I keep seal kits on hand for Bosch VA AR, BR, and CR versions of the IH Neuss pumps that are in for repair and calibration. Bosch does not have parts support for the VA pump anymore, so they MUST be handled carefully. Break one critical part inside, and good luck finding another..
