Got bent auger fixed.
69stang
Bent the unloading auger last time I used it. Working good now.
Just the auger. The tube got pushed out a couple feet and then auger bent before i could shut it off. I did rotate the tube 180 degrees caus it was getting a little thin on the bottom.
Quite awhile ago a neighbor came to my shop with an IH grinder-mixer with an auger bent like a pretzel. He got too close to the wall in the alleyway of his corn crib. IH was made by Artsway and the Artsway factory is a little over an hour away from here so it was easy to get a new auger. Some of the vertical auger was bent too so it was not a cheap repair.
