I have old tractor with a loader. Can't find a name on loader valve but ports are marked In,Out,and Bypass. The Bypas is plugged. It shows 1000 PSI all the time. loader and bucket work ok. Took out the bypass
plug and found a spool and removed it. Now only pressure when I move valve levers but the bucket is only one way now. If I put spool back in and run a line from bypas to tank will it work right.
