New Holland 488 Mo/Co Swathing Grain
connor9988
Location
Central Iowa
We have a NH 488 and the manual makes it sound like we could open the rollers enough to swath rye and barley without crushing it and use the pickup head on our A6 combine to harvest it.
If this is true I would need to free up the roller adjusting levers but it would be something interesting to try.
Thoughts?
I've only cut hay with my 479. Those cranks on the back don't change the clearance of the rollers. They only put more spring tension on the rollers. To get more space there are shims to put in place and increase the gap. I think I've removed a lot of my spacers because the rubber rollers are so worn that they don't crush the hay much.
I have the rolls blocked open about a half inch. But better yet mine is one of those that have lost most of the rubber off one roll. I think the cranks only adjust the pressure on the rolls. Maybe they could be backed off enough so there is no pressure on the rolls . ?
My brother has been doing it with oats for years with a NH 479, jambs a piece of 2x4 block in each end of the rollers to keep them apart, then same as Doug Wi, cut early in the morning when the dew is on the grain.
When you say each end do you mean where the roller spacers normally hold them open? How do you force the rollers apart in the first place?
How much gap can be achieved?
Thanks.
On a NH haybine it is very easy to spread rolls. Just use the crank that adjusts roll pressure and back it off Completely and rolls will spread apart to make it a swather. I was told about that from a good old NH mechanic years ago. Worked good for me many tears. He said many don't know it but a Haybine is a swather, just crank rolls open all the way.
(quoted from post at 11:46:43 02/28/21) On a NH haybine it is very easy to spread rolls. Just use the crank that adjusts roll pressure and back it off .
That does not spread the rollers apart on my 479. It only lowers the tension on the springs. To spread them you have to install shims at each end. Unless the rollers are old and worn out like mine and I had to take shims out to get the rollers closer together.
