So we hauled in a Farmall cub. Hooked up a battery to see if it would spin over. Well it would not. It would move a little but that was it. Pulled the plugs and pumped ATF into each cylinder and let sit a little bit and did some other things. Came back to it and it spun over just fine. Used the starter to get it closer to the shop. Tried all 3 forward gears and it pulled it self just fine. It isn't in the shop yet but only about 50 feet from it. Now I need a carb and also probably going have to figure out how to get to the points in the mag. Gas tank is about half full of old gas and will not flow out of the sediment bowl
