teddy52food
Why is there not enough power to run the heaters in winter when they have enough to run all the air conditioners when it gets over 100 degrees in hot weather? Also why do they have to boil the drinking water now?
s(quoted from post at 12:04:31 02/18/21) Depends on what part of the state your in. Here in Centerville the power has never gone off.The main problem with our power grid. Is too many people moving to the state.They have overloaded the system. I am 70 and when I was a kid power failures were rare.
Boling the water kills any germs. But most stock up on bottled water before a storm.
(quoted from post at 12:23:39 02/18/21)They are being asked to boil water because there is no power to their water treatment plants.
(quoted from post at 12:42:11 02/18/21) So 17% reduction in the power grid on days when the grid would be taxed anyway sounds like a problem to me. Plus I heard it on the news so it must be true.
(quoted from post at 09:16:01 02/18/21) First off winter is maintenance time in the south.
We do maintenance on electric plants and oil refineries in the winter.
So some of the electric plants in Texas were shut down during these normally slow time of the year.
Couple that with some renewable production went down.
They under predicted maximum daily usage.
They are not hooked to the national grid.
And you got the start of a problem brewing.
Then you add in the unprecedented cold that we are not equipped to handle.
But the main reason the grid went down in Texas is the Natural gas supply.
Texas gets over 50% of its electricity from natural gas.
Because of their ready supply of gas they do not have much storage.
Because of the cold the normal gas supply from west Texas to the big cities in the east was cut off due to freezing problems.
Without a steady fuel supply electric production was not able to keep up.
The water has the same problem.
We are not equipped for the cold.
With so many letting the water drip to keep the pipes from freezing the water treatment plant gets over whelmed.
Once the water pressure gets to a set low amount it automatically triggers a boil water order.
(quoted from post at 09:29:18 02/18/21) Several reasons.
When it's 100* and you want 70* in the house, you're only looking at a 30* difference.
When it's 0* and you want 70*, that's 70* difference.
Also air conditioning is simply picking up the heat and putting it outside.
Heating requires converting energy to heat. A much more demanding process.
And we're not prepared for extreme cold, the buildings are not properly insulated to contain heat.
Now we're facing another problem, water! Broken pipes are thawing, water blowing everywhere, depleting the system.
Pressure dropping, boil requirements. Hard to boil water with the power off.
Apartments are the worst, broken pipes flooding multiple stories, unlivable conditions!
(quoted from post at 11:13:12 02/18/21) You're absolutely right about the scammers!
They're running public service announcements about them on TV.
(quoted from post at 15:12:59 02/18/21) Texas is not hooked to the grid because being a intrastate business they do not fall under federal regulations and over sight.
The laws they follow are made in Austin not D.C.
