1946 BN IHC
To those who know hydraulics better than I <<>><
I am working on an Ingersoll Rand Lawn tractor [ case 224]. Some one before me has toggled the feed tubes using a rubber hose from the supply tank to the pump. The line / I take it to be the return line [goes to the cooler rad] is steel with rubber hose couplings.
>>The line in question is the line that goes from the supply tank to the pump<< it has been toggled up with a rubber hose.
???? now the question ?? I would like to replace this piece with a flexible 3/8 copper line and fittings. ??Is this the correct method of replacement?, since this line is not a pressure line, probably just a supply line.
Thank you to those who know hydraulic lines and fittings better than I.
.Wm.
.Wm.
