Midway
I have my nieghbors #7 IH horse drawn mower. He mowed his pasture with it and a JD H tractor years ago. He passed away and I would like to mow with it now and again for fun. No hard work just to see it cut. I have it operational but like to know what gear oil was used in the gear box. I have read not to use 90w. What do you suggest ? I have a Farmall SC I would pull it with. I know to go slow with it. Thanks for your reply.
I have a McCormack Deering mower and it works okay. Just don't go to slow as horses walked faster than most people think. When I a boy I mowed with a team and they moved right along. You had to rest them quite often as a mower hung quite heavy on them. My mower has the gear box behind the axle so it is a bit lighter than some on the tongue. Also make sure the tongue is about the same height as it would be hooked to a team of horses. That's important to make it cut good. Good Luck and have fun.
2X what MtMan said sickle bars plug too much if you go too slow. They like fairly mature stemmy grass too.
Here is what it says in #7 book. Hope is big enough to read. SAE20 not heavy trans oil.
