Engine stand
SVcummins
Decided I’d give the northern tool engine one ton engine stand a try and see how it is . I’m hoping I can find a pivot gear box Or maybe just buy a gear box from surplus center and modify that to turn the engine . This stand has outriggers that you can lower to hold the stand from moving that was probably what sold me on it
Engine stand northern tool
I am Leary of that engine staying up on that stand. I don’t know how they say 2000 lbs. be ok with just the block. Just hate to see it flip over.
Should be able to just rig up a couple sprockets and chain with a hand crank on the back. Big and small sprocket. But when it gets to flipping on the side you might need a brake. As u know once it’s off centre they are in free fall.
Yes, the third picture where the small stand is inside the big one. That’s what is needed.
I heard of a truck shop using an old school slack adjuster from truck brakes to roll an engine in a stand. The old school ones had a lock ring that held the adjustment in one place when not pushed in with a wrench (or socket). I never saw it as the shop was closed down when i heard of it by one of the guys who had worked there. He said it worked great.
If I remember right, mine is 30:1. I dont think I'd want much less. I think some of the factory built stands sport a 90:1 ratio.
There’s a few videos on YouTube of those engines on these one ton stands so hopefully it’ll work out . I’m not that Much of a builder so if have to I think I can modify this one if I need too . These engines aren’t that heavy actually I can roll it over quite easily by hand when I had it on my work table but I really wanted to see how these stands are . This is about the largest engine I’ll ever do .
I suppose I could go pull the final drive off my 7700 combine and build the one like mr Tim s built but I’m really hoping to only have to do one more big engine and I wouldn’t care if it was the last one I ever did the rest of my life would suite me
We have a Cummins mounted on a stand similar to what you have shown. Ours is more of a display for students, so we mounted the stand on the right side of the engine with a plate made in our welding department.
Looking at the specs it's too small for a big engine. JMO. A little under three feet long and a little over two feet wide. There is going to be too much engine sticking out past the stand whether you bolt it to the end or on the side. That will make it very unstable when you turn it. The stops won't help you there. This is assuming the steel is heavy enough to support the load. You can't just go by engine weight as every inch away from the post reduces capacity.
A friend of mine used an old timing gear set from a small block Chevy that worked real slick,big gear on the shaft that went to the engine,small gear on a bracket down below with chain between them and a old crank handle off a boat winch,still used the cross pin in the top shaft to locate it at the four positions.
I have the same stand,only it's Harbor frieght. It's had 390 Ford,350 chevy on it. It's had IH 56 series transmission houseings(TA job). It would be fine for your 3020 motor,the 4020 motor might be a bit heavy.But I have no complaints.It's done what it was supposed to do.
That stands engine mount spin has no bearings or rollers of any sort might be tough to rotate with 1000lbs hanging out there.
Might have to alter where it spins.
Might consider using 1/4" steel rods inside the outer pipe.
Change shaft on engine mount to be 1/2" less diameter to ride on those homemade roller bearings.
At same time that smaller shaft can extend out to accommodate whatever gearbox you choose for rotation.
I would use worm drive gear box. Maybe off of a hand crank winch.
I think it sill prove a little small as well . I’m hoping to only rotate the engine once before installing the head then leave it upright the after that
