Hello guys. Just got that new to me Ford 1500 diesel tractor. Have ordered glow plugs from ebag which may get here by the end of the month.
Have researched the various heater options. This one is a little 2 cylinder nippon Shibaura diesel. What I want is some kind of circulating heater that will keep the whole engine warm. Not sure a block heater will work for this tiny engine and don't want a magnetic oil pan heater cause I want the heat up around the head and cylinders. The circulating ones are made to go on a heater hose which this one doesn't have. It has 1 1/4" radiator hoses.
Question is will a lower radiator hose heater heat the water hot enough to open the thermostat and flow throughout the engine or do they heat the water in the block without having to go through the thermostat? Thanks.
