Check out this Ford
grandpa Love
Bit too far away for me but sure is an
odd ball. Great price too. Wonder what
is was originally for? City or county?
If it was closer I would at least go
look, with a trailer.......and cash! 😆
Maybe this link works
If I had 5 acres of lawn to mow instead of 2, it would be a good mower.
I don't like the fact that it ties up the tractor so it can't be used to drag logs or pull a plow.
Richard
Good thing I'm in FL for the winter. Tires look to be worth 1/2 the price of the tractor. Good time for you to visit the Steel City with a trailer. No crowds and nnalert light traffic.
Quite a rig but I like it,it'd sure beat a P-O-S mower from Lowes for the same or a lot more $$$$.Your 'forever' mower.To make it a better deal get a set of turf tires which can usually be picked up for cheap and use those tires on one of your other tractors.
I saw that on FB yesterday.
Yes, heavy and expensive mower.
Also odd for a row crop tractor with high CG.
Dean
It's so wide you would need a deckover to haul it home, that or have to be close enough to drive it home. Odd also that the tires are set out wider than the mower deck. Cant mow closer than the tires allow you to get up to things. Front could be narrowed alot, but not sure how much if any the rear tires could be narrowed.
Good looking rig. The front spindle steering arms are on the wrong side, they should be pointing to the center of the final drive "axle" in the middle of the rear, and they point outward. It will steer poorely in almost any medium turn angle. Jim
