Ellis Kinney
Working on the brakes on an M Farmall. I have lost the pin that goes through the brake cover to the frame of the tractor. The one that the two ends of the brake band fit to with the two little triangle pieces welded on. Without going into too much detail, I have looked for two days. Most of you will know what it looks like without a picture. It is the left one, but I don't know if they can be switched from side to side. To make matters worse it is the side for my M&W hand clutch. Does anybody know if it was modified (slightly longer) for the hand clutch? Anybody happen to have one? Thanks, Ellis
