Dozed scraper blade for front bucket
Rkh
I can't scrape my blacktop clear of snow because my mf65 gas front bucket is not on level. It is about 3/4" off from being level. Its hard from looking at the picture that its off level. Do you guys recommend putting a scraper blade on my front bucket edge?
Check your rear tire pressure. If one is a little low it will tip the tractor and loader to one side. Sometimes tires that are marked as the same size can vary in height as well.
Mark
Yes park on a flat surface and release air in one rear tire until level.on my work backhoe I just swing the boom to the higher side until level
I was working on the neighbor's 450 Farmall and I put a level across ed the loader arms and then on the bucket. I showed him that when someone did a repair on the frame, that they did not get it aligned with the bucket. Check the loader arms with a level and then the bucket. If they are aligned with each other, then you might need to check where the frame mounts to the tractor.
like nhu@ufe said check your rear tires pressure and are they a matched set a few pounds difference will make it out of wack
(quoted from post at 14:46:42 12/22/20) Fronts have 33lbs
Rears have 10lbs & 5lbs loaded with weights & calcium
If 10 lbs and 5 lbs. are the pressures of your rears there is your problem.
