VinceMF240
Needing some help with my tractor, I inherited a MF240 from a relative. Its set up for years Ive replaced fuel filters and pumped all the old diesel out and put fresh diesel in it along with some hot shot. Once the tractor is started it runs fine but getting it to start in the cold has proven to be a headache and Ive had to use starting fluid a few times. The tractor only has 312 hrs on it and once I first start turning it over theres no smoke coming out of the exhaust so this leads me to believe its a fuel issue.
Where do I need to start to fix this problem? Ive already spent $1500 on hydraulic lines, alternator, fluids and filters, battery, gauges etc. Its turned into a mild restore but the warming months are coming and I need to get the hard starting issue fixed and Im trying not to waste money on things that wont fix my issue. Thank you in advance
