Trying to contact 1) connie minnie 2 ) NY 986
Syncro
New User
If anyone knows member named connie minnie and/or member named NY 986 please ask them to contact me at my email ( [email protected] ) since because they were talking they had JD plows for possible sale, from 10/20 and 10/29 blogs.
Thanks For The Help,
Phil Hunsberger in SW Michigan
I posted relative to what appeared to be a JD F245 plow for sale on Craigslist Williamsport, PA. The listing was removed by the author the following day so my assumption is that he finally sold it. I hope this clears up what happened with that plow. I have a JD 2800 6 bottom on land plow that I would not mind parting with. Coonie has already responded as to his plow so I guess not much more to say at this point for me. Good luck in your search.
Thank you for the help by responding about the plows. I'm not exactly certain what the status is with NY 986 as to whether he still has a plow for sale or not? I will try to contact him. If you know more as to that, please inform me. ........THANK YOU... Syncro
I think that you mean Coonie Minnie. He had a JD F360 8 bottom plow in his shed or did have. I was looking at an ad on Craigslist that I saw for my home turf of the Finger Lakes that originated in PA. That plow has not been listed for a while now. Hope this clears things up.
Thanks for the help. I'm trying to find more about 8 bottom mentioned in a blog from 10/2 and 10/29.
John, No I didn't see an email from you. I'll check again. But I'm new here and confused some because under a heading from connie minnie the message says connie minnie is not known. I assumed the bold type is the SENDER and I am now questioning if it identifies the TOPIC ?
That would be Coonie's. I have the JD 2800 which I imagine would be common as dirt and I am sure that there are nicer 2800 plows between NY and MI. I still would consider selling it if that is what you want.
(quoted from post at 09:35:46 12/03/20) John, No I didn't see an email from you. I'll check again. But I'm new here and confused some because under a heading from connie minnie the message says connie minnie is not known. I assumed the bold type is the SENDER and I am now questioning if it identifies the TOPIC ?
cOOnie, not coNNie.
